A 4 GHz digital receiver using the Uniboard platform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Millimeter Année : 2012
The Uniboard is a general purpose board, developed as a part of the Radionet FP7 program, that hosts 8 Altera StratixIV FPGAs interconnected by high speed links. It can be used standalone or as a part of a more complex system. The Digital receiver application uses a single Uniboard to implement a flexible packetization of a wideband signal in the frequency domain. It accepts a 4 GHz (8 GS/s) input bandwidth and provides up to 64 output bands. The bandwidth and position of each output band can be independently adjusted. The input signal is first analyzed by a polyphase filterbank, that splits the input band into 32 sub-bands with a bandwidth of 190 MHz and a spacing of 128 MHz. The overlap among adjacent bands allows the positioning of the output bands without dead regions. This filterbank is followed by an array of digitally defined downconverters, each one composed of a mixer/LO and a variable decimation filter. The filter band can be adjusted in binary steps from 1 to 128 MHz. Using tap recirculation, the filter shape remains constant over this whole range, with about 60 dB of stopband rejection and 90% usable passband. The output bands are packetized according to the VDIF VLBI standard, over eight 10G Ethernet links. Further processing can be done either on board, or in a cluster of conventional PCs. In addition, high speed ADC are in-house developed (ASIC 65nm CMOS STmicroelectronics) to feed the Uniboard card with 8GS/s, 4GHz BW, 3bits samples.
Fichier non déposé
hal-00752244 , version 1 (15-11-2012)
Giovanni Comoretto, Antonietta Russo, Benjamin Quertier, Ph. Cais, Pascal Camino. A 4 GHz digital receiver using the Uniboard platform. Millimeter, Submillimeter, and Far-Infrared Detectors and Instrumentation for Astronomy VI. Proceedings of the SPIE, Volume 8452, id. 84522L-84522L-10 (2012), 2012, France. pp.id. 84522L-84522L-10, ⟨10.1117/12.924809⟩. ⟨hal-00752244⟩
Collections
INSU CNRS L3AB
84 Consultations
0 Téléchargements
