Large scale dynamics in flux driven gyrokinetic turbulence
Yanick Sarazin 1 Virginie Grandgirard 1 Jérémie Abiteboul 1 S. Allfrey 1 Xavier Garbet 1 Philippe Ghendrih 1 Guillaume Latu 1, 2 A. Strugarek 1 Guilhem Dif-Pradalier 3
2 CALVI - Scientific computation and visualization
IRMA - Institut de Recherche Mathématique Avancée, LSIIT - Laboratoire des Sciences de l'Image, de l'Informatique et de la Télédétection, Inria Nancy - Grand Est, IECL - Institut Élie Cartan de Lorraine
Abstract : The turbulent transport governed by the toroidal ion temperature gradient driven instability is analysed with the full-f global gyrokinetic code GYSELA (Grandgirard et al 2007 Plasma Phys. Control. Fusion 49 B173) when the system is driven by a prescribed heat source. Weak, yet finite, collisionality governs a neoclassical ion heat flux that can compete with the turbulent driven transport. In turn, the ratio of turbulent to neoclassical transport increases with the source magnitude, resulting in the degradation of confinement with additional power. The turbulent flux exhibits avalanche-like events, characterized by intermittent outbursts which propagate ballistically roughly at the diamagnetic velocity. Locally, the temperature gradient can drop well below the linear stability threshold. Large outbursts are found to correlate with streamer-like structures of the convection cells albeit their Fourier spectrum departs significantly from that of the most unstable linear modes. Last, the poloidal rotation of turbulent eddies is essentially governed by the radial electric field at moderate density gradient.
Type de document :
Article dans une revue
Nuclear Fusion, IOP Publishing, 2010, 50 (5), pp.054004. 〈10.1088/0029-5515/50/5/054004〉
Liste complète des métadonnées
https://hal.inria.fr/hal-00756091
Contributeur : Ist Inria Nancy Grand Est <>
Soumis le : jeudi 22 novembre 2012 - 14:51:20
Dernière modification le : jeudi 15 mars 2018 - 01:37:30
Lien texte intégral
Citation
Yanick Sarazin, Virginie Grandgirard, Jérémie Abiteboul, S. Allfrey, Xavier Garbet, et al.. Large scale dynamics in flux driven gyrokinetic turbulence. Nuclear Fusion, IOP Publishing, 2010, 50 (5), pp.054004. 〈10.1088/0029-5515/50/5/054004〉. 〈hal-00756091〉
Métriques
Consultations de la notice
298
