Variable Neighborhood Search for Robust Optimization and Applications to Aerodynamics - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
(1) , (2) , (2) , (2)
1
2
Many real-life applications lead to the definition of robust optimization problems where the objective function is a black box. This may be due, for example, to the fact that the objective function is evaluated through computer simulations, and that some parameters are uncertain. When this is the case, existing algorithms for optimization are not able to provide good-quality solutions in general. We propose a heuristic algorithm for solving black box robust optimization problems based on the minimax formulation of the problem.We also apply this algorithm for the solution of a wing shape optimization where the objective function is a computationally expensive black box. Preliminary computational experiments are reported.
Not file
Dates and versions
hal-00756948 , version 1 (24-11-2012)
Identifiers
  • HAL Id : hal-00756948 , version 1
Cite
Antonio Mucherino, Fuchs Martin, Serge Gratton, Vasseur Xavier. Variable Neighborhood Search for Robust Optimization and Applications to Aerodynamics. 8th International Conference on Large-Scale Scientific Computations (LSSC11), 2012, Sozopol, Bulgaria. pp.230-237. ⟨hal-00756948⟩
213 View
0 Download
Share
