Constraints on the Use of Language, Gesture and Speech for Multimodal Dialogues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
We try to show how language, gesture and perception can be seen in a uniform way from the perspective of referential analysis, by looking at the specific constraints which underly the speaker's choice of a given expression. To this end, we first situate the relative importance of speech and gesture in man-machine communication. Then, we concentrate upon the specific effects resulting from the combination of verbal, gestural and perceptual information, showing that on the one hand the three provide structural constraints to the objects which are being referred to and on the other hand that any referring operation, whatever its origin, has to be interpreted within a localized frame, with some consequences upon dialogue management.
W97-1413.pdf (508.06 Ko) Télécharger le fichier
hal-00757452 , version 1 (27-11-2012)
  • HAL Id : hal-00757452 , version 1
Bertrand Gaiffe, Laurent Romary. Constraints on the Use of Language, Gesture and Speech for Multimodal Dialogues. Constraints On The Use Of Language Gesture And Speech For Multimodal Dialogues, ACL Special Interest Group on Multimedia Language Processing (SIGMEDIA), Jul 1997, Madrid, Spain. pp.94-98. ⟨hal-00757452⟩
257 Consultations
73 Téléchargements
