Revisiting Value Prediction
Value prediction was proposed in the mid 90's to enhance the performance of high-end microprocessors. Unfortunately, to the best of our knowledge, there are no Value Prediction implementations available on the market. Moreover, the research on Value Prediction techniques almost vanished in the early 2000's as it was more effective to increase the number of cores than to dedicate silicon to Value Prediction. However, high-end processor chips currently feature 8-16 high-end cores and the technology will allow to implement 50-100 of such cores on a single die in a foreseeable future. Amdahl's law suggests that the performance of most workloads will not scale to that level. Therefore, dedicating more silicon area to single high-end core will be considered as worthwhile for future multicores, either in the context of heterogeneous multicores or homogeneous multicore. In particular, spending transistors on specialized, performance and/or power optimized units, such as a value predictor. In this report, we first build on the concept of value prediction. We introduce a new value predictor VTAGE harnessing the global branch history. VTAGE directly inherits the structure of the indirect jump predictor ITTAGE. We show that VTAGE is able to predict with a very high accuracy many values that were not correctly predicted by previously proposed predictors, such as the FCM predictor and the stride predictor. Compared with these previously proposed solutions, VTAGE can accommodate very long prediction latencies. The introduction of VTAGE opens the path to the design of new hybrid predictors. Three sources of information can be harnessed by these predictors: the global branch history, the differences of successive values and the local history of values. We show that the predictor components using these %three sources of information are all amenable to very high accuracy at the cost of some prediction coverage. %On SPEC 2006 Using SPEC 2006 benchmarks, our study shows that with a large hybrid predictor, in average 56.76% of the values can be predicted with a 99.48% accuracy against respectively 55.50% and 98.62% without advanced confidence estimation and the VTAGE component.
La prédiction de valeur a été proposée dans les années 90 pour améliorer la performance des processeurs haut de gamme. Malheureusement, à notre connaissance, aucune implémentation n'est disponible sur le marché. De plus, la recherche dédiée aux techniques de prédiction a presque disparue au début des années 2000 car il était plus intéréssant d'augmenter le nombre de coeurs que de dédier du silicium à cette technique. Cependant, les processeurs haut de gamme possèdent de nos jours 8 à 16 coeurs et les progrès technologiques futurs permettront d'implémenter 50 à 100 coeurs similaires aux coeurs actuels sur une seule puce. De plus, la loi d'Amdahl suggère que la performance de la majorité des programmes ne passera pas à l'échelle sur un tel nombre de coeurs. Conséquemment, dédier plus de surface de silicium à un unique coeur haute performance sera considéré comme digne d'intérêt pour les futurs multicoeurs, que ce soit dans le contexte des multicoeurs hétérogènes ou homogènes. En particulier, dépenser des transistors dans des unités optimisées pour la performance et/ou la consommation, tel qu'un prédicteur de valeur. Dans ce rapport, nous commen\c cons par augmenter le concept de prédiction de valeurs. Nous introduisons un nouveau prédicteur de valeur VTAGE tirant parti de l'historique global de branchement. VTAGE hérite directement de la structure du prédicteur de sauts indirects ITTAGE. Nous montrons que VTAGE est capable de prédire avec une très haute précision un grand nombre de valeurs n'étant pas prédites correctement par les prédicteurs proposés précédemment, tels que le prédicteur FCM ou le prédicteur Stride. Contrairement à ces solutions, VTAGE n'est pas impacté par la latence de la prédiction. L'introduction de VTAGE rend aussi possible l'utilisation de nouveaux prédicteurs hybrides. Trois sources d'informations peuvent être utilisées par ces prédicteurs : L'historique global de branchement, la différence entre les valeurs successivement produites et l'historique local des valeurs. Nous montrons que les composants utilisant ces sources d'informations peuvent tous atteindre une très haute précision au prix d'une perte de couverture. En utilisant des benchmarks de la suite SPEC 2006, notre étude montre qu'avec un grand prédicteur hybride, en moyenne 56.76% des valeurs peuvent être prédites avec une précision de 99.48%, contre respectivement 55.50% et 98.62% sans notre méchanisme d'estimation de confiance avancé et VTAGE.
Architectures Matérielles [cs.AR]
