Climatically-Active Gases In The Eastern Boundary Upwelling And Oxygen Minimum Zone (Omz) Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The EBUS (Eastern Boundary Upwelling Systems) and OMZs (Oxygen Minimum Zone) contribute very significantly to the gas exchange between the ocean and the atmosphere, notably with respect to the greenhouse gases (hereafter GHG). From in-situ ocean measurements, the uncertainty of the net global ocean-atmosphere CO2 fluxes is between 20 and 30%, and could be much higher in the EBUS-OMZ. Off Peru, very few in-situ data are available presently, which justifies alternative approaches for assessing these fluxes.
garbe_IGARSS2012b.pdf (711.4 Ko) Télécharger le fichier
hal-00760423 , version 1 (03-12-2012)
Christoph Garbe, Andre Butz, Isabelle Dadou, Boris Dewitte, Veronique Garçon, et al.. Climatically-Active Gases In The Eastern Boundary Upwelling And Oxygen Minimum Zone (Omz) Systems. Geoscience and Remote Sensing Symposium (IGARSS), 2012 IEEE International, IEEE, Jul 2012, Munich, Germany. pp.6150 - 6153, ⟨10.1109/IGARSS.2012.6352740⟩. ⟨hal-00760423⟩
922 Consultations
167 Téléchargements
