New ODE Model for Diffusion MRI Signal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Water diffusion in biological tissues is not Gaussian and signal attenuation is not monoexponential with b-value [1]. Approaches to deal with this behavior include the bi-exponential model [1,2], the Karger model [3], and Kurtosis approach [4]. We formulate an ODE model for diffusion MRI signal that is more general than Karger model, valid for more general diffusion gradient shapes and gives a good approximation to the ADC and Kurtosis. Given DMRI signals before and after cell swelling, we can estimate the amount of cell swelling after numerically solving an ODE system.
ODE_Model.pdf (478.26 Ko) Télécharger le fichier
hal-00764195 , version 1 (12-12-2012)
  • HAL Id : hal-00764195 , version 1
Hang Tuan Nguyen, Jing-Rebecca Li, Denis S. Grebenkov. New ODE Model for Diffusion MRI Signal. MRPM11, Sep 2012, Surrey, United Kingdom. ⟨hal-00764195⟩
297 Consultations
91 Téléchargements
