New interface
Reports (Research report)
Routing Scheme for a Wireless Sensor Network Real-Time Locating System
Laurent Ciarletta 1 Hugo Cruz-Sanchez 1 Ye-Qiong Song 1 Priyadarsi Nanda 2
1 MADYNES - Management of dynamic networks and services
Inria Nancy - Grand Est, LORIA - NSS - Department of Networks, Systems and Services
Abstract : This work contains a routing proposition to be used over a Wireless Sensor Network (WSN) location system based on the IEEE 802.15.4 standard. The technical solution for communication consists of an n-ary tree algorithm for routing using a 16 bit addressing scheme. It is compared to a binary routing scheme originally used on a real system which suffers from coverage, routing and addressing problem. An analysis of the coverage aspects is driven by a geometric study. It includes an analysis of a generated topology for different coverage areas and different routing topologies. The geometric analysis is validated by a simulation work. We observe that the proposed scheme outperforms the existing routing solution in therms of hop-count, delay and association process time. The work puts in evidence that the Connectivity of the network is an important parameter to be considered during the network deployment and for the routing scheme.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-00764931
Contributor : Laurent Ciarletta Connect in order to contact the contributor
Submitted on : Thursday, December 13, 2012 - 4:43:25 PM
Last modification on : Friday, November 18, 2022 - 10:13:49 AM
Identifiers
  • HAL Id : hal-00764931, version 1
Collections
Citation
Laurent Ciarletta, Hugo Cruz-Sanchez, Ye-Qiong Song, Priyadarsi Nanda. Routing Scheme for a Wireless Sensor Network Real-Time Locating System. [Research Report] Loria & Inria Grand Est. 2012, pp.6. ⟨hal-00764931⟩
Share
Metrics
Record views
163
