Results of the Ontology Alignment Evaluation Initiative 2012 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ernesto Jimenez-Ruiz
Pavel Shvaiko
  • Fonction : Auteur
  • PersonId : 1323368
Ontology matching consists of finding correspondences between semantically related entities of two ontologies. OAEI campaigns aim at comparing ontology matching systems on precisely defined test cases. These test cases can use ontologies of different nature (from simple thesauri to expressive OWL ontologies) and use different modalities, e.g., blind evaluation, open evaluation, consensus. OAEI 2012 offered 7 tracks with 9 test cases followed by 21 participants. Since 2010, the campaign has been using a new evaluation modality which provides more automation to the evaluation. This paper is an overall presentation of the OAEI 2012 campaign.
oaei12_paper0.pdf (368.01 Ko) Télécharger le fichier
hal-00768409 , version 1 (21-12-2012)
  • HAL Id : hal-00768409 , version 1
José Luis Aguirre, Bernardo Cuenca Grau, Kai Eckert, Jérôme Euzenat, Alfio Ferrara, et al.. Results of the Ontology Alignment Evaluation Initiative 2012. Proc. 7th ISWC workshop on ontology matching (OM), Nov 2012, Boston, United States. pp.73-115. ⟨hal-00768409⟩
1113 Consultations
438 Téléchargements
