Simulation of low Reynolds number flow control over a backward-facing step using pulsed inlet velocities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics Research eXpress Année : 2004
In this work a control procedure is applied to a two-dimensional slightly compressible flow over a backward-facing step. This low Reynolds number flow is computed by a Direct Numerical Simulation method and validated for some existing experimental and numerical results. Then, an oscillating inlet flow variation is applied to control the flow behavior inside the channel. The amplitude and the frequency effects are especially analyzed to obtain a better understanding of their influence on the shedding evolution and the recirculation zone behavior.
Fichier non déposé
hal-00768712 , version 1 (23-12-2012)
  • HAL Id : hal-00768712 , version 1
Emmanuel Creusé, Iraj Mortazavi. Simulation of low Reynolds number flow control over a backward-facing step using pulsed inlet velocities. Applied Mathematics Research eXpress, 2004, 4, pp.133-152. ⟨hal-00768712⟩
90 Consultations
0 Téléchargements
