New interface
Journal articles
A performance analysis of channel fragmentation in dynamic spectrum access systems
Abstract : Dynamic Spectrum Access systems offer temporarily available spectrum to opportunistic users capable of spreading transmissions over a number of non-contiguous subchannels. Such methods can be highly beneficial in terms of spectrum utilization, but excessive fragmentation degrades performance and hence off-sets the benefits. To get some insight into acceptable levels of fragmentation, we present experimental and analytical results derived from a mathematical model. According to the model, a system operates at capacity serving requests for bandwidth by assigning a collection of one or more gaps of unused bandwidth to each request as bandwidth becomes available. Our main result is a proof that, even if fragments can be arbitrarily small, the system remains stable in the sense that the average total number of fragments remains bounded. Within the class of dynamic fragmentation models, including models of dynamic storage allocation that have been around for many decades, this result appears to be the first of its kind. In addition, we provide extensive experimental results that describe behavior, at times unexpected, of fragmentation as parameter values are varied. Different scanning rules for searching gaps of available spectrum, all covered by the above stability result, are also studied. Our model applies to dynamic linked-list storage allocation, and provides a novel analysis in that domain. We prove that, interestingly, a version of the 50 % rule of the classical, non-fragmented allocation model holds for the new model as well. Overall, the paper provides insights into the behavior of practical fragmentation algorithms.
keyword : stocmod
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00773105
Contributor : Philippe Robert Connect in order to contact the contributor
Submitted on : Friday, January 11, 2013 - 3:54:56 PM
Last modification on : Saturday, November 19, 2022 - 3:59:00 AM
Links full text
Identifiers
Citation
Ed Coffman, Philippe Robert, Florian Simatos, Shuzo Tarumi, Gil Zussman. A performance analysis of channel fragmentation in dynamic spectrum access systems. Queueing Systems, 2012, 71 (3), pp.293-320. ⟨10.1007/s11134-012-9317-7⟩. ⟨hal-00773105⟩
Share
Metrics
Record views
92
