Improving the detection of On-line Vertical Port Scan in IP Traffic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose in this paper an on-line algorithm based on Bloom filters to detect port scan attacks in IP traffic. Only relevant information about destination IP addresses and destination ports are stored in two steps in a two-dimensional Bloom filter. This algorithm can be indefinitely performed on a real traffic stream thanks to a new adaptive refreshing scheme that closely follows traffic variations. It is a scalable algorithm able to deal with IP traffic at a very high bit rate thanks to the use of hashing functions over a sliding window. Moreover it does not need any a priori knowledge about traffic characteristics. When tested against real IP traffic, the proposed on-line algorithm performs well in the sense that it detects all the port scan attacks within a very short response time of only 10 seconds without any false positive.
IJSSE.pdf (689.66 Ko) Télécharger le fichier
hal-00773108 , version 1 (29-11-2013)
Yousra Chabchoub, Christine Fricker, Philippe Robert. Improving the detection of On-line Vertical Port Scan in IP Traffic. CRiSIS 2012 - 7th International Conference on Risks and Security of Internet and Systems, Oct 2012, Cork, Ireland. pp.1-6, ⟨10.1109/CRISIS.2012.6378945⟩. ⟨hal-00773108⟩
392 Consultations
457 Téléchargements
