AN ANALYSIS OF CONVEX RELAXATIONS FOR MAP ESTIMATION OF DISCRETE MRFs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue JMLR Année : 2009
The problem of obtaining the maximum a posteriori estimate of a general discrete Markov random field (i.e., a Markov random field defined using a discrete set of labels) is known to be NP-hard. However, due to its central importance in many applications, several approximation algorithms have been proposed in the literature. In this paper, we present an analysis of three such algorithms based on convex relaxations: (i)LP-S: the linear programming (LP) relaxation proposed by Schlesinger for a special case and independently by Chekuri et al., Koster et al., and Wainwright et al. for the general case; (ii) QP-RL: the quadratic programming (QP) relaxation of Ravikumar and Lafferty; and (iii) SOCP-MS: the second order cone programming (SOCP) relaxation first proposed by Muramatsu and Suzuki for two label problems and later extended by Kumar et al. for a general label set. We show that the SOCP-MS and the QP-RL relaxations are equivalent. Furthermore, we prove that despite the flexibility in the form of the constraints/objective function offered by QP and SOCP, the LP-S relaxation strictly dominates (i.e., provides a better approximation than) QP-RL and SOCP-MS. We generalize these results by defining a large class of SOCP (and equivalent QP) relaxations which is dominated by the LP-S relaxation. Based on these results we propose some novel SOCP relaxations which define constraints using random variables that form cycles or cliques in the graphical model representation of the random field. Using some examples we show that the new SOCP relaxations strictly dominate the previous approaches
KKT-JMLR2009.pdf (527.61 Ko) Télécharger le fichier
hal-00773608 , version 1 (14-01-2013)
  • HAL Id : hal-00773608 , version 1
M. Pawan Kumar, Vladimir Kolmogorov, Philip H.S. Torr. AN ANALYSIS OF CONVEX RELAXATIONS FOR MAP ESTIMATION OF DISCRETE MRFs. JMLR, 2009. ⟨hal-00773608⟩
67 Consultations
109 Téléchargements
