New interface
Reports (Research report)
Sur les carreaux de Bézier rationnels de degré 2. Partie 1
Paul-Louis George 1 Houman Borouchaki 1
1 Gamma3 - Automatic mesh generation and advanced methods
Inria Paris-Rocquencourt, ICD - Institut Charles Delaunay
Abstract : Following our previous reports related to classical Lagrange finite elements of degree 2, we consider the case of rational Bézier patches not as a method to define a surface (and then a mapping from $\R^2$ to $\R^3$) but as the support of a calculus (therefore a mapping from $\R^2$ to $\R^2$). In this usage, the jacobian of the mapping must be positive and this is the point discussed in this report for both a quad patch and a hex patch. Part 2 discusses the case of triangular and tet patches.
Document type :
Complete list of metadata
Cited literature [4 references]  Display  Hide  Download
https://hal.inria.fr/hal-00776189
Contributor : Paul-Louis George Connect in order to contact the contributor
Submitted on : Tuesday, January 15, 2013 - 11:13:19 AM
Last modification on : Wednesday, October 26, 2022 - 8:16:09 AM
Long-term archiving on: : Tuesday, April 16, 2013 - 3:53:56 AM
File
RR-8201.pdf
Identifiers
  • HAL Id : hal-00776189, version 1
Collections
Citation
Paul-Louis George, Houman Borouchaki. Sur les carreaux de Bézier rationnels de degré 2. Partie 1. [Rapport de recherche] RR-8201, INRIA. 2013, pp.51. ⟨hal-00776189⟩
Share
Metrics
Record views
149
Files downloads
141
