Journal articles
Efficient unfolding of contextual Petri nets
Abstract : A contextual net is a Petri net extended with read arcs, which allows transitions to check for tokens without consuming them. Contextual nets allow for better modelling of concurrent read access than Petri nets, and their unfoldings can be exponentially more compact than those of a corresponding Petri net. A constructive but abstract procedure for generating those unfoldings was proposed in previous work. However, it remained unclear whether the approach was useful in practice and which data structures and algorithms would be appropriate to implement it. Here, we address this question. We provide two concrete methods for computing contextual unfoldings, with a view to efficiency. We report on experiments carried out on a number of benchmarks. These show that not only are contextual unfoldings more compact than Petri net unfoldings, but they can be computed with the same or better efficiency, in particular with respect to alternative approaches based on encodings of contextual nets into Petri nets.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00776752
Contributor : Benedikt Bollig Connect in order to contact the contributor
Submitted on : Wednesday, January 16, 2013 - 10:29:26 AM
Last modification on : Thursday, January 20, 2022 - 4:13:06 PM
Links full text
Identifiers
Citation
Paolo Baldan, Alessandro Bruni, Andrea Corradini, Barbara König, César Rodríguez, et al.. Efficient unfolding of contextual Petri nets. Theoretical Computer Science, Elsevier, 2012, 449 (1), pp.2-22. ⟨10.1016/j.tcs.2012.04.046⟩. ⟨hal-00776752⟩
Share
Metrics
Record views
111
