PAULA XML Documentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
PAULA XML or PAULA for short (Potsdamer AUstauschformat Linguistischer Annotationen, 'Potsdam Exchange Format for Linguistic Annotations') is a standoff XML format designed to represent a wide range of linguistically annotated textual and multi-modal corpora. The format was created at Potsdam University and developed within SFB 632, the collaborative research centre "Information Structure", subproject D1, "Linguistic Database" at Potsdam University and Humboldt- Universität zu Berlin. The description below represents the normative documentation for PAULA version 1.1, with some notes on previous versions of PAULA. For the latest documentation always check the PAULA Website which also contains an online HTML version of this documentation.
PAULA_P1.1.2013.1.21a.pdf (393.8 Ko) Télécharger le fichier
hal-00783716 , version 1 (01-02-2013)
  • HAL Id : hal-00783716 , version 1
Amir Zeldes, Florian Zipser, Arne Neumann. PAULA XML Documentation. [Research Report] 2013, pp.38. ⟨hal-00783716⟩
Collections
INRIA INRIA2 LARA
390 Consultations
846 Téléchargements
