Two Asymptotic Models for Arrays of Underground Waste Containers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applicable Analysis Année : 2009
We study the homogenization of two models of an underground nuclear waste repository. The nuclear waste cells are periodically stored in the middle of a geological layer and are the only source terms in a parabolic evolution problem. The diffusion constants have a very large contrast between the fuel repository and the soil. It is thus a combined problem of homogenization and singular perturbation. For two different asymptotic contrasts we give the homogenized limit problem which is rigorously justified by using two-scale convergence. Eventually we perform 2-d numerical computations to show the effectiveness of using the limit model instead of the original one.
657.pdf (1.28 Mo) Télécharger le fichier
hal-00784062 , version 1 (04-08-2020)
  • HAL Id : hal-00784062 , version 1
Grégoire Allaire, M. Briane, R. Brizzi, Y. Capdeboscq. Two Asymptotic Models for Arrays of Underground Waste Containers. Applicable Analysis, 2009, 88, pp.1445-1467. ⟨hal-00784062⟩
101 Consultations
53 Téléchargements
