Software Calibration of Wirelessly Networked Sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper presents our work with wireless sensor networks for the calibration of the embedded sensor chips located in each wireless sensor networks node. We propose a software compensation applied on data sources for each devices. We implement such a calibration process at the initialization of the wireless sensor networks and we propose a software module on each node to regularly improve the measurement accuracy. The results shows the temperature measurements improvements for our energy efficiency in building testbed.
Fichier non déposé
hal-00786272 , version 1 (08-02-2013)
Bernard Tourancheau, Yannis Mazzer, Gérard Krauss, Valentin Marvan, Frederic Kuznick. Software Calibration of Wirelessly Networked Sensors. SensorComm 2009 - The Third International Conference on Sensor Technologies and Applications, 2009, Athènes, Greece. ⟨10.1109/SENSORCOMM.2009.56⟩. ⟨hal-00786272⟩
60 Consultations
0 Téléchargements
