Kripke Semantics and Proof Systems for Combining Intuitionistic Logic and Classical Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of Pure and Applied Logic Année : 2013
We combine intuitionistic logic and classical logic into a new, first-order logic called Polarized Intuitionistic Logic. This logic is based on a distinction between two dual polarities which we call red and green to distinguish them from other forms of polarization. The meaning of these polarities is defined model-theoretically by a Kripke-style semantics for the logic. Two proof systems are also formulated. The first system extends Gentzen's intuitionistic sequent calculus LJ. In addition, this system also bears essential similarities to Girard's LC proof system for classical logic. The second proof system is based on a semantic tableau and extends Dragalin's multiple-conclusion version of intuitionistic sequent calculus. We show that soundness and completeness hold for these notions of semantics and proofs, from which it follows that cut is admissible in the proof systems and that the propositional fragment of the logic is decidable.
pil-final.pdf (403.35 Ko) Télécharger le fichier
hal-00787601 , version 1 (12-02-2013)
Chuck Liang, Dale Miller. Kripke Semantics and Proof Systems for Combining Intuitionistic Logic and Classical Logic. Annals of Pure and Applied Logic, 2013, 164 (2), pp.86-111. ⟨10.1016/j.apal.2012.09.005⟩. ⟨hal-00787601⟩
6018 Consultations
1292 Téléchargements
