New interface
Journal articles
Daubechies Wavelets for High Performance Electronice Structure Calculations: the BigDFT Project
Abstract : In this contribution we will describe in detail a Density Functional Theory method based on a Daubechies wavelets basis set, named BigDFT. We will see that, thanks to wavelet properties, this code shows high systematic convergence properties, very good performances and an excellent efficiency for parallel calculations. BigDFT code operation are also well-suited for GPU acceleration. We will discuss how the problematic of fruitfully benefit of this new technology can be match with the needs of robustness and flexibility of a complex code like BigDFT. This work may be of interest not only for expert in electronic structure calculations, but may also provide feedback to the wider community of high performance scientific computing.
Complete list of metadata
https://hal.inria.fr/hal-00788765
Contributor : Arnaud Legrand Connect in order to contact the contributor
Submitted on : Friday, February 15, 2013 - 11:09:51 AM
Last modification on : Wednesday, July 6, 2022 - 4:12:37 AM
Identifiers
Collections
Citation
Luigi Genovese, Brice Videau, Matthieu Ospici, Thierry Deutsch, Stefan Godecker, et al.. Daubechies Wavelets for High Performance Electronice Structure Calculations: the BigDFT Project. Comptes rendus hebdomadaires des séances de l'Académie des sciences, 2011, 339, pp.149-164. ⟨10.1016/j.crme.2010.12.003⟩. ⟨hal-00788765⟩
Share
Metrics
Record views
146
