New interface
Conference papers
Scheduling Distributed Applications: the SimGrid Simulation Framework
Abstract : Since the advent of distributed computer systems an active field of research has been the investigation of scheduling strategies for parallel applications. The common approach is to employ scheduling heuristics that approximate an optimal schedule. Unfortunately, it is often impossible to obtain analytical results to compare the efficacy of these heuristics. One possibility is to conducts large numbers of back-to-back experiments on real platforms. While this is possible on tightly-coupled platforms, it is infeasible on modern distributed platforms (i.e. Grids) as it is labor-intensive and does not enable repeatable results. The solution is to resort to simulations. Simulations not only enables repeatable results but also make it possible to explore wide ranges of platform and application scenarios. In this paper we present the SimGrid framework which enables the simulation of distributed applications in distributed computing environments for the specific purpose of developing and evaluating scheduling algorithms. This paper focuses on SimGrid v2, which greatly improves on the first version of the software with more realistic network models and topologies. SimGrid v2 also enables the simulation of distributed scheduling agents, which has become critical for current scheduling research in large-scale platforms. After describing and validating these features, we present a case study by which we demonstrate the usefulness of SimGrid for conducting scheduling research.
Complete list of metadata
https://hal.inria.fr/hal-00789451
Contributor : Arnaud Legrand Connect in order to contact the contributor
Submitted on : Monday, February 18, 2013 - 11:51:43 AM
Last modification on : Wednesday, November 30, 2022 - 11:22:07 AM
Identifiers
  • HAL Id : hal-00789451, version 1
Collections
Citation
Henri Casanova, Arnaud Legrand, Loris Marchal. Scheduling Distributed Applications: the SimGrid Simulation Framework. Proceedings of the Third IEEE International Symposium on Cluster Computing and the Grid (CCGrid\'03), 2003, Unknown. ⟨hal-00789451⟩
Share
Metrics
Record views
124
