New interface
Journal articles
Équilibrage de Charge Statique Pour Noyaux Dálgèbre Linéaire Sur Plate-Forme Hétérogène
Arnaud Legrand 1
1 REMAP - Regularity and massive parallel computing
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : In this paper, we deal with algorithmic issues on heterogeneous platforms. We concentrate on dense linear algebra kernels, such as matrix multiplication or LU decomposition. Block cyclic distribution techniques used in ScaLAPACK are no longer sufficient to balance the load among processors running at different speeds. The main result of this paper is to provide a static data distribution scheme that leads to an asymptotically perfect load balancing for LU decomposition, thereby providing solid foundations toward the design of a cluster-oriented version of ScaLAPACK.
Complete list of metadata
https://hal.inria.fr/hal-00789469
Contributor : Arnaud Legrand Connect in order to contact the contributor
Submitted on : Monday, February 18, 2013 - 11:52:10 AM
Last modification on : Tuesday, October 25, 2022 - 4:17:05 PM
Identifiers
  • HAL Id : hal-00789469, version 1
Collections
Citation
Arnaud Legrand. Équilibrage de Charge Statique Pour Noyaux Dálgèbre Linéaire Sur Plate-Forme Hétérogène. Revue des Sciences et Technologies de l'Information - Série TSI : Technique et Science Informatiques, 2002, 21 (5), pp.711-734. ⟨hal-00789469⟩
Share
Metrics
Record views
60
