Results of the first evaluation of matching tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Contrat/Projet) Année : 2010
This deliverable reports the results of the first SEALS evaluation campaign, which has been carried out in coordination with the OAEI 2010 campaign. A subset of the OAEI tracks has been included in a new modality, the SEALS modality. From the participant's point of view, the main innovation is the use of a web-based interface for launching evaluations. 13 systems, out of 15 for all tracks, have participated in some of the three SEALS tracks. We report the preliminary results of these systems for each SEALS track and discuss the main lesson learned from to the use of the new technology for both participants and organizers of the OAEI.
seals-123.pdf (2.41 Mo) Télécharger le fichier
hal-00793288 , version 1 (22-02-2013)
  • HAL Id : hal-00793288 , version 1
Cassia Trojahn dos Santos, Christian Meilicke, Jérôme Euzenat, Ondrej Sváb-Zamazal. Results of the first evaluation of matching tools. [Contract] 2010, pp.36. ⟨hal-00793288⟩
245 Consultations
78 Téléchargements
