New interface
Journal articles
Tissue at risk in the deep middle cerebral artery territory is critical to stroke outcome.
Abstract : INTRODUCTION: The clinical efficacy of thrombolysis in stroke patients is explained by the increased rate of recanalization, which limits infarct growth. However, the efficacy could also be explained by the protection of specific sites of the brain. Here, we investigate where is this outcome-related tissue at risk using voxel-based analysis. METHODS: We included 68 acute stroke patients with middle cerebral artery (MCA) occlusion on the admission MRI performed within 6 h of symptoms onset (H6) and 16 controls. MCA recanalization was assessed using the magnetic resonance angiography performed at day 1 (D1). Apparent diffusion coefficient (ADC) changes were analyzed using a voxel-based method between patients vs. controls group at admission (H6) in non-recanalized vs. recanalized and in 3-month poor vs. good outcome patients at D1. RESULTS: Complete or partial MCA recanalization was observed in 52 of 68 patients. Good outcome at 3 months occurred in 40 patients (59%). In non-recanalized patients, ADC was decreased in the deep MCA and watershed arterial territory (the lenticular nucleus, internal capsule, and the overlying periventricular white matter). This decrease was not observed in recanalized patients at D1 or patients at H6. Fiber tracking suggested that the area is crossed by the cortico-spinal, cerebellar, and intra-hemispheric association tracts. Finally, this area almost co-localized with the area associated with poor outcome. CONCLUSIONS: A clinically relevant area of tissue at risk may occur in patients with MCA infarcts at the level of deep white matter fiber tracts. These findings suggest that neuroprotection research should be refocused on white matter.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00795756
Contributor : Olivier Colliot Connect in order to contact the contributor
Submitted on : Thursday, February 28, 2013 - 7:29:28 PM
Last modification on : Friday, August 5, 2022 - 3:41:46 AM
Links full text
Identifiers
Citation
Charlotte Rosso, Olivier Colliot, Romain Valabrègue, Sophie Crozier, Didier Dormont, et al.. Tissue at risk in the deep middle cerebral artery territory is critical to stroke outcome.. Neuroradiology, 2011, 53 (10), pp.763-71. ⟨10.1007/s00234-011-0916-5⟩. ⟨hal-00795756⟩
Share
Metrics
Record views
52
