Journal articles
Detection of paroxysmal atrial fibrillation with transtelephonic EKG in TIA or stroke patients.
Abstract : BACKGROUND: Paroxysmal atrial fibrillation (PAF) may remain underdiagnosed after stroke, as suggested by long-duration EKG monitoring. Here we report the sensitivity of transtelephonic EKG monitoring (TTM) for detection of PAF in patients following a recent stroke or TIA and a negative 24-hour Holter. METHODS: We analyzed data from 98 consecutive patients with TTM and noncardioembolic TOAST stroke (n = 78) or TIA (n = 20). Most were cryptogenic events (82%). Patients started TTM 0.8 months (interquartile range 0.4-2.5) after the indexed event and randomly recorded about 1 EKG per day for 1 month. Univariate and multivariate analyses were run to identify PAF predictors. RESULTS: Seventeen PAF episodes were detected in 9.2% (9/98) of the patients. The estimated duration of PAF episodes ranged from 4 to 72 hours. Two predictors were identified: premature atrial ectopic beats (more than 100) in 24-hour routine Holter (odds ratio [OR] = 11.0; 95% confidence interval [CI] 1.9-62; p = 0.007) and nonlacunar anterior circulation DWI hypersignals (OR = 9.9; 95% CI 1.1-90.6; p = 0.04). The PAF detection rate varied from 42.6% for patients meeting both criteria to 0% for patients with neither of them. CONCLUSIONS: Transtelephonic EKG monitoring increases detection rate of paroxysmal atrial fibrillation in stroke and TIA patients whose 24-hour Holter result was negative, especially if they had frequent premature atrial ectopic beats, recent anterior circulation infarct on MRI, or both.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00795770
Contributor : Olivier Colliot Connect in order to contact the contributor
Submitted on : Thursday, February 28, 2013 - 7:51:26 PM
Last modification on : Saturday, June 18, 2022 - 4:09:39 AM
Identifiers
Citation
N. Gaillard, S. Deltour, B. Vilotijevic, A. Hornych, S. Crozier, et al.. Detection of paroxysmal atrial fibrillation with transtelephonic EKG in TIA or stroke patients.. Neurology, American Academy of Neurology, 2010, 74 (21), pp.1666-70. ⟨10.1212/WNL.0b013e3181e0427e⟩. ⟨hal-00795770⟩
Share
Metrics
Record views
338
