A Framework for Throughput and Energy Efficiency in Mobile ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose a general framework to evaluate and compare both throughput and energy efficiency of mobile ad hoc networks. This framework is built upon a probabilistic, energy-aware, calculus for the analysis of broadcast, unicast and multicast wireless communications. The results of our analyses can be used to replace a network component with a more efficient one - with respect to different metrics like throughput and energy consumption - while maintaining connectivity. As an application, we evaluate two well-known automatic repeat request (ARQ)-based error control protocols: stop-and-wait (SW) and go-back-N (GBN).
WD2011.pdf (537 Ko) Télécharger le fichier
hal-00799168 , version 1 (11-03-2013)
  • HAL Id : hal-00799168 , version 1
Lucia Gallina, Sardaouna Hamadou, Andrea Marin, Sabina Rossi. A Framework for Throughput and Energy Efficiency in Mobile ad Hoc Networks. IFIP Wireless Days Conference, Oct 2011, Niagara Falls, ON, Canada. pp.1-6. ⟨hal-00799168⟩
225 Consultations
161 Téléchargements
