ECOFIT: A Framework to Estimate Energy Consumption of Fault Tolerance protocols during HPC executions - Archive ouverte HAL Access content directly
Conference Papers Year : 2013
(1, 2) , (1, 2) , (1, 2, 3) , (4, 5, 6)
1
2
3
4
5
6
Energy consumption and fault tolerance are two interrelated issues to address for designing future exascale systems. Fault tolerance protocols used for checkpointing have different energy consumption depending on parameters like application features, number of processes in the execution and platform characteristics. Currently, the only way to select a protocol for a given execution is to run the application and monitor the energy consumption of different fault tolerance protocols. This is needed for any variation of the execution setting. To avoid this time and energy consuming process, we propose an energy estimation framework. It relies on an energy calibration of the considered platform and a user description of the execution setting. We evaluate the accuracy of our estimations with real applications running on a real platform with energy consumption monitoring. Results show that our estimations are highly accurate and allow selecting the best fault tolerant protocol without pre-executing the application.
Not file
Dates and versions
hal-00806500 , version 1 (31-03-2013)
Identifiers
  • HAL Id : hal-00806500 , version 1
Cite
Mohammed El Mehdi Diouri, Olivier Glück, Laurent Lefèvre, Franck Cappello. ECOFIT: A Framework to Estimate Energy Consumption of Fault Tolerance protocols during HPC executions. 13th IEEE/ACM International Symposium on Cluster, Cloud and Grid Computing (CCGrid), May 2013, Delft, Netherlands. ⟨hal-00806500⟩
297 View
0 Download
Share
