Effects of dopaminergic and subthalamic stimulation on musical performance. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Neural Transmission Année : 2013
Although subthalamic-deep brain stimulation (STN-DBS) is an efficient treatment for Parkinson's disease (PD), its effects on fine motor functions are not clear. We present the case of a professional violinist with PD treated with STN-DBS. DBS improved musical articulation, intonation and emotional expression and worsened timing relative to a timekeeper (metronome). The same effects were found for dopaminergic treatment. These results suggest that STN-DBS, mimicking the effects of dopaminergic stimulation, improves fine-tuned motor behaviour whilst impairing timing precision.
hal-00817575 , version 1 (24-04-2013)
Floris T van Vugt, Michael Schüpbach, Eckart Altenmüller, Eric Bardinet, Jérôme Yelnik, et al.. Effects of dopaminergic and subthalamic stimulation on musical performance.. Journal of Neural Transmission, 2013, 120 (5), pp.755-9. ⟨10.1007/s00702-012-0923-7⟩. ⟨hal-00817575⟩
50 Consultations
0 Téléchargements
