New interface
Conference papers
Estimation of smooth growth trajectories with controlled acceleration from time series shape data.
Abstract : Longitudinal shape analysis often relies on the estimation of a realistic continuous growth scenario from data sparsely distributed in time. In this paper, we propose a new type of growth model parameterized by acceleration, whereas standard methods typically control the velocity. This mimics the behavior of biological tissue as a mechanical system driven by external forces. The growth trajectories are estimated as smooth flows of deformations, which are twice differentiable. This differs from piecewise geodesic regression, for which the velocity may be discontinuous. We evaluate our approach on a set of anatomical structures of the same subject, scanned 16 times between 4 and 8 years of age. We show our acceleration based method estimates smooth growth, demonstrating improved regularity compared to piecewise geodesic regression. Leave-several-out experiments show that our method is robust to missing observations, as well as being less sensitive to noise, and is therefore more likely to capture the underlying biological growth.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00818406
Contributor : Stanley Durrleman Connect in order to contact the contributor
Submitted on : Friday, April 26, 2013 - 5:45:05 PM
Last modification on : Monday, November 16, 2020 - 10:52:06 AM
Links full text
Identifiers
Citation
James Fishbaugh, Stanley Durrleman, Guido Gerig. Estimation of smooth growth trajectories with controlled acceleration from time series shape data.. MICCAI - Medical Image Computing And Computer Assisted Intervention, Sep 2011, Toronto, Canada. pp.401-418, ⟨10.1007/978-3-642-23629-7_49⟩. ⟨hal-00818406⟩
Share
Metrics
Record views
54
