On the Use of a Proportional-Share Market for Application SLO Support in Clouds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Virtualization provides increased control and flexibility on how resources are allocated to applications. However, common resource provisioning mechanisms do not fully use these advantages; either they provide limited support for applications demanding quality of service, or the resource allocation complexity is high. To address these issues we developed Themis, a market-based application management platform. By limiting the coupling between the applications and resource manage- ment, Themis can support diverse types of applications and performance goals while ensuring maximized resource usage. In this paper we analyze the resource management mechanisms of Themis. We present the perfor- mance of Themis in the case in which users execute batch applications with Service Level Objectives such as deadlines.
Fichier non déposé
hal-00821558 , version 1 (10-05-2013)
  • HAL Id : hal-00821558 , version 1
Stefania Victoria Costache, Nikos Parlavantzas, Christine Morin, Samuel Kortas. On the Use of a Proportional-Share Market for Application SLO Support in Clouds. Europar -19th International European Conference on Parallel and Distributed Computing - 2013, Aug 2013, Aachen, Germany. ⟨hal-00821558⟩
224 Consultations
0 Téléchargements
