Higher Quality 2D Text Rendering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computer Graphics Techniques Année : 2013
Nicolas P. Rougier
Even though text is pervasive in most 3D applications, there is surprisingly no native sup- port for text rendering in OpenGL. To cope with this absence, Mark Kilgard introduced the use of texture fonts [Kilgard 1997]. This technique is well known and widely used and en- sures both good performances and a decent quality in most situations. However, the quality may degrade strongly in orthographic mode (screen space) due to pixelation effects at large sizes and to legibility problems at small sizes due to incorrect hinting and positioning of glyphs. In this paper, we consider font-texture rendering to develop methods to ensure the highest quality in orthographic mode. The method used allows for both the accurate render- ing and positioning of any glyph on the screen. While the method is compatible with complex shaping and/or layout (e.g., the Arabic alphabet), these specific cases are not studied in this article.
paper.pdf (1.14 Mo) Télécharger le fichier
hal-00821839 , version 1 (13-05-2013)
  • HAL Id : hal-00821839 , version 1
Nicolas P. Rougier. Higher Quality 2D Text Rendering. Journal of Computer Graphics Techniques, 2013, 2 (1), pp.50-64. ⟨hal-00821839⟩
Collections
CNRS INRIA INRIA2
638 Consultations
3612 Téléchargements
