Journal articles
Anisotropic Diffusion for Details Enhancement in Multiexposure Image Fusion
Abstract : We have developed a multiexposure image fusion method based on texture features, which exploits the edge preserving and intraregion smoothing property of nonlinear diffusion filters based on partial differential equations (PDE). With the captured multiexposure image series, we first decompose images into base layers and detail layers to extract sharp details and fine details, respectively. The magnitude of the gradient of the image intensity is utilized to encourage smoothness at homogeneous regions in preference to inhomogeneous regions. Then, we have considered texture features of the base layer to generate a mask (i.e., decision mask) that guides the fusion of base layers in multiresolution fashion. Finally, well-exposed fused image is obtained that combines fused base layer and the detail layers at each scale across all the input exposures. Proposed algorithm skipping complex High Dynamic Range Image (HDRI) generation and tone mapping steps to produce detail preserving image for display on standard dynamic range display devices. Moreover, our technique is effective for blending flash/no-flash image pair and multifocus images, that is, images focused on different targets.
Complete list of metadata
https://hal.inria.fr/hal-00824046
Contributor : Vinay Kumar Connect in order to contact the contributor
Submitted on : Monday, May 20, 2013 - 6:33:56 PM
Last modification on : Tuesday, July 13, 2021 - 4:22:10 PM
Long-term archiving on: : Tuesday, April 4, 2017 - 8:32:13 AM
File
Anisotropic_Diffusion_for_Deta...
Publisher files allowed on an open archive
Identifiers
Citation
Harbinder Singh, Vinay Kumar, Sunil Bhooshan. Anisotropic Diffusion for Details Enhancement in Multiexposure Image Fusion. International Scholarly Research Notices, Hindawi, 2013, 2013 (Article ID 928971), pp.18. ⟨10.1155/2013/928971⟩. ⟨hal-00824046⟩
Share
Metrics
Record views
87
Files downloads
551
