Towards design patterns for ontology alignment
Aligning ontologies is a crucial and tedious task. Matching algorithms and tools provide support to facilitate the task of the user in defining correspondences between ontologies entities. However, automatic matching is actually limited to the detection of simple one to one correspondences to be further refined by the user. We introduce in this paper Correspondence Patterns as a tool to assist the design of ontology alignments. Based on existing research on patterns in the fields of software and ontology engineering, we define a pattern template and use it to develop a correspondence patterns library. This library is published in RDF following the Alignment Ontology vocabulary.
