On the Equilibrium of Simplicial Masonry Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2013
Fernando de Goes
  • Fonction : Auteur
  • PersonId : 873934
Pierre Alliez
Mathieu Desbrun
We present a novel approach for the analysis and design of selfsupporting simplicial masonry structures. A finite-dimensional formulation of their compressive stress field is derived, offering a new interpretation of thrust networks through numerical homogenization theory. We further leverage geometric properties of the resulting force diagram to identify a set of reduced coordinates characterizing the equilibrium of simplicial masonry. We finally derive computational form-finding tools that improve over previous work in efficiency, accuracy, and scalability.
Mots clés
masonry-13.pdf (8.41 Mo) Télécharger le fichier
Format : Figure, Image
hal-00826280 , version 1 (27-05-2013)
  • HAL Id : hal-00826280 , version 1
Fernando de Goes, Pierre Alliez, Houman Owhadi, Mathieu Desbrun. On the Equilibrium of Simplicial Masonry Structures. ACM Transactions on Graphics, 2013, Proceedings of SIGGRAPH, 32 (4). ⟨hal-00826280⟩
Collections
INRIA INRIA2
1245 Consultations
3101 Téléchargements
