The Denormal Logarithmic Number System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mark G. Arnold
  • Fonction : Auteur
  • PersonId : 942372
Caroline Collange
Economical hardware often uses a FiXed-point Number System (FXNS), whose constant absolute precision is acceptable for many signal-processing algorithms. The almost-constant relative precision of the more expensive Floating-Point (FP) number system simplifies design, for example, by eliminating worries about FXNS overflow because the range of FP is much larger than FXNS for the same wordsize; however, primitive FP introduces another problem: underflow. The conventional Signed Logarithmic Number System (SLNS) offers similar range and precision as FP with much better performance (in terms of power, speed and area) for multiplication, division, powers and roots. Moderate-precision addition in SLNS uses table lookup with properties similar to FP (including underflow). This paper proposes a new number system, called the Denormal LNS (DLNS), which is a hybrid of the properties of FXNS and SLNS. The inspiration for DLNS comes from the denormal numbers found in IEEE-754 (that provide better, gradual underflow) and the µ-law often used for speech encoding; the novel DLNS circuit here allows arithmetic to be performed directly on such encoded data. The proposed approach allows customizing the range in which gradual underflow occurs. A wide gradual underflow range acts like FXNS; a narrow one acts like SLNS. Simulation of an FFT application illustrates a moderate gradual underflow decreasing bit-switching activity 15% compared to underflow-free SLNS, at the cost of increasing application error by 30%. DLNS reduces switching activity 5% to 20% more than an abruptly-underflowing SLNS with one-half the error. Synthesis shows the novel circuit primarily consists of traditional SLNS addition and subtraction tables, with additional datapaths that allow the novel ALU to act on conventional SLNS as well as DLNS and mixed data, for a worst-case area overhead of 26%.
Arnold_DenormLNS_ASAP13.pdf (262.26 Ko) Télécharger le fichier
hal-00832505 , version 1 (10-06-2013)
  • HAL Id : hal-00832505 , version 1
Mark G. Arnold, Caroline Collange. The Denormal Logarithmic Number System. ASAP 2013 - 24th IEEE International Conference on Application-specific Systems, Architectures and Processors, Jun 2013, Washington D.C., United States. pp.117-124. ⟨hal-00832505⟩
330 Consultations
506 Téléchargements
