Extended Resolution as Certificates for Propositional Logic
When checking answers coming from automatic provers, or when skeptically integrating them into proof assistants, a major problem is the wide variety of formats of certificates, which forces to write lots of different checkers. In this paper, we propose to use the extended resolution as a common format for every propositional prover. To be able to do this, we detail two algorithms transforming proofs computed respectively by tableaux provers and provers based on BDDs into this format. Since this latter is already implemented for SAT solvers, it is now possible for the three most common propositional provers to share the same certificates.
Logique en informatique [cs.LO]
