New interface
Journal articles
Streaming an image through the eye: The retina seen as a dithered scalable image coder
Khaled Masmoudi 1 Marc Antonini 1 Pierre Kornprobst 2
2 NEUROMATHCOMP - Mathematical and Computational Neuroscience
CRISAM - Inria Sophia Antipolis - Méditerranée , JAD - Laboratoire Jean Alexandre Dieudonné : UMR6621
Abstract : We propose the design of an original scalable image coder/decoder that is inspired from the mammalians retina. Our coder accounts for the time-dependent and also non-deterministic behavior of the actual retina. The present work brings two main contributions: As a first step, (i) we design a deterministic image coder mimicking most of the retinal processing stages and then (ii) we introduce a retinal noise in the coding process, that we model here as a dither signal, to gain interesting perceptual features. Regarding our first contribution, our main source of inspiration will be the biologically plausible model of the retina called Virtual Retina. The coder that we propose has two stages. The first stage is an image transform which is performed by the outer layers of the retina. Here we model it by filtering the image with a bank of difference of Gaussians with time-delays. The second stage is a time-dependent analog-to-digital conversion which is performed by the inner layers of the retina. The main novelty of this coder is to show that the time-dependent behavior of the retina cells could ensure, in an implicit way, scalability and bit allocation. Regarding our second contribution, we reconsider the inner layers of the retina. We emit a possible interpretation for the non-determinism observed by neurophysiologists in their output. For this sake, we model the retinal noise that occurs in these layers by a dither signal. The dithering process that we propose adds several interesting features to our image coder. The dither noise whitens the reconstruction error and decorrelates it from the input stimuli. Furthermore, integrating the dither noise in our coder allows a faster recognition of the fine details of the image during the decoding process. Our present paper goal is twofold. First, we aim at mimicking as closely as possible the retina for the design of a novel image coder while keeping encouraging performances. Second, we bring a new insight concerning the non-deterministic behavior of the retina.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00845592
Contributor : Pierre Kornprobst Connect in order to contact the contributor
Submitted on : Wednesday, July 17, 2013 - 2:13:49 PM
Last modification on : Friday, August 5, 2022 - 3:50:29 AM
Links full text
Identifiers
Citation
Khaled Masmoudi, Marc Antonini, Pierre Kornprobst. Streaming an image through the eye: The retina seen as a dithered scalable image coder. Signal Processing: Image Communication, 2012, ⟨10.1016/j.image.2012.07.005⟩. ⟨hal-00845592⟩
Share
Metrics
Record views
274
