Random Spatial Structure of Geometric Deformations and Bayesian Nonparametrics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Christof Seiler
  • Fonction : Auteur
  • PersonId : 943875
Susan Holmes
  • Fonction : Auteur
  • PersonId : 943876
Our work is motivated by the geometric study of lower back pain from patient CT images. In this paper, we take a first step towards that goal by introducing a data-driven way of identifying anatomical regions of interest. We propose a probabilistic model of the geometrical variability and describe individual patients as noisy deformations of a random spatial structure (modeled as regions) from a common template. The random regions are generated using the distance dependent Chinese Restaurant Process. We employ the Gibbs sampler to infer regions from a set of noisy deformation fields. Each step of the sampler involves model selection (Bayes factor) to decide about fusing regions. In the discussion, we highlight connections between image registration and Markov chain Monte Carlo methods.
BayesianNonparametricsGeometricDeformationsSeiler2013.pdf (504.19 Ko) Télécharger le fichier
hal-00847185 , version 1 (22-07-2013)
Christof Seiler, Xavier Pennec, Susan Holmes. Random Spatial Structure of Geometric Deformations and Bayesian Nonparametrics. GSI - Geometric Science of Information - 2013, Aug 2013, Paris, France. pp.120-127, ⟨10.1007/978-3-642-40020-9_12⟩. ⟨hal-00847185⟩
Collections
INRIA INRIA2
146 Consultations
329 Téléchargements
