Delaunay triangulation of imprecise points, preprocess and actually get a fast query time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olivier Devillers
We propose a new algorithm to preprocess a set of n disjoint unit disks in O(n log n) expected time, allowing to compute the Delaunay triangulation of a set of n points, one from each disk, in O(n) expected time. This work reaches the same asymptotical theoretical complexities as previous results on this problem, but our algorithm is much simpler and efficient in practice.
hal.pdf (288.66 Ko) Télécharger le fichier
Format : Figure, Image
hal-00850583 , version 1 (07-08-2013)
  • HAL Id : hal-00850583 , version 1
Olivier Devillers. Delaunay triangulation of imprecise points, preprocess and actually get a fast query time. XIV Spanish Meeting on Computational Geometry,, 2011, Alcala de Henares, Spain. ⟨hal-00850583⟩
120 Consultations
137 Téléchargements
