A Tutorial on Runtime Verification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
Klaus Havelund
  • Fonction : Auteur
  • PersonId : 974234
Giles Reger
  • Fonction : Auteur
This tutorial presents an overview of the field referred as to runtime verification. Runtime Verification is the study of algorithms, data structures, and tools focused on analyzing executions of system. The performed analysis aims at improving the confidence in systems behavior, either by improving program understanding, or by checking conformance to specifications or algorithms. This chapter focuses specifically on checking execution traces against requirements formalized in terms of monitors. It is first shown on examples how such monitors can be written using aspect-oriented programming, exemplified by ASPECTJ. Subsequently four monitoring systems are illustrated on the same examples. The systems cover such formalisms as regular expressions, temporal logics, state machines, and rule-based programming, as well as the distinction between external and internal DSLs.
Fichier non déposé
hal-00853727 , version 1 (23-08-2013)
Yliès Falcone, Klaus Havelund, Giles Reger. A Tutorial on Runtime Verification. Manfred Broy, Doron Peled, Georg Kalus. Engineering Dependable Software Systems, 34, IOS Press, pp.141-175, 2013, NATO Science for Peace and Security Series - D: Information and Communication Security, 978-1-61499-206-6 (print); 978-1-61499-207-3 (online). ⟨10.3233/978-1-61499-207-3-141⟩. ⟨hal-00853727⟩
471 Consultations
0 Téléchargements
