Regional myocardial wall thinning at multidetector computed tomography correlates to arrhythmogenic substrate in postinfarction ventricular tachycardia: assessment of structural and electrical substrate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Circulation. Arrhythmia and electrophysiology Année : 2013
Yuki Komatsu
  • Fonction : Auteur
Hubert Cochet
  • Fonction : Auteur
  • PersonId : 880054
Amir Jadidi
  • Fonction : Auteur
Frédéric Sacher
  • Fonction : Auteur
Ashok Shah
  • Fonction : Auteur
Nicolas Derval
  • Fonction : Auteur
Daniel Scherr
  • Fonction : Auteur
Patrizio Pascale
  • Fonction : Auteur
Laurent Roten
  • Fonction : Auteur
Arnaud Denis
  • Fonction : Auteur
Khaled Ramoul
  • Fonction : Auteur
Shinsuke Miyazaki
  • Fonction : Auteur
Matthew Daly
  • Fonction : Auteur
Jatin Relan
  • Fonction : Auteur
  • PersonId : 761727
  • IdRef : 167644211
Mélèze Hocini
  • Fonction : Auteur
Michel Haïssaguerre
  • Fonction : Auteur
Pierre Jaïs
  • Fonction : Auteur
A majority of patients undergoing ablation of ventricular tachycardia have implanted devices precluding substrate imaging with delayed-enhancement MRI. Contrast-enhanced multidetector computed tomography (MDCT) can depict myocardial wall thickness with submillimetric resolution. We evaluated the relationship between regional myocardial wall thinning (WT) imaged by MDCT and arrhythmogenic substrate in postinfarction ventricular tachycardia.We studied 13 consecutive postinfarction patients undergoing MDCT before ablation. MDCT data were integrated with high-density 3-dimensional electroanatomic maps acquired during sinus rhythm (endocardium, 509±291 points/map; epicardium, 716±323 points/map). Low-voltage areas (100 ms after QRS complex) were almost exclusively detected within the thinnest area (93% in the WT<3 mm).Regional myocardial WT correlates to low-voltage regions and distribution of LAVA critical for the generation and maintenance of postinfarction ventricular tachycardia. The integration of MDCT WT with 3-dimensional electroanatomic maps can help focus mapping and ablation on the culprit regions, even when MRI is precluded by the presence of implanted devices.
hal-00855932 , version 1 (30-08-2013)
Yuki Komatsu, Hubert Cochet, Amir Jadidi, Frédéric Sacher, Ashok Shah, et al.. Regional myocardial wall thinning at multidetector computed tomography correlates to arrhythmogenic substrate in postinfarction ventricular tachycardia: assessment of structural and electrical substrate. Circulation. Arrhythmia and electrophysiology, 2013, 6 (2), pp.342-350. ⟨10.1161/CIRCEP.112.000191⟩. ⟨hal-00855932⟩
Collections
INRIA INRIA2 ANR
233 Consultations
0 Téléchargements
