Heterogeneous Matrix-Matrix Multiplication or Partitioning a Square into Rectangles: NP-Completeness and Approximation Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Vincent Boudet
Fabrice Rastello
Yves Robert
In this paper, we deal with two geometric problems arising from heterogeneous parallel computing: how to partition the unit square into p rectangles of given area s₁, s₂,..., sₚ (such that the sum of the s_i is equal to 1), so as to minimize (i) either the sum of the p perimeters of the rectangles (ii) or the largest perimeter of the p rectangles. For both problems, we prove NP-completeness and we introduce approximation algorithms.
Fichier non déposé
hal-00856643 , version 1 (02-09-2013)
  • HAL Id : hal-00856643 , version 1
Olivier Beaumont, Vincent Boudet, Fabrice Rastello, Yves Robert. Heterogeneous Matrix-Matrix Multiplication or Partitioning a Square into Rectangles: NP-Completeness and Approximation Algorithms. [Research Report] 2000-10, 2000. ⟨hal-00856643⟩
84 Consultations
0 Téléchargements
