Spirograph Designs for Ambient Display of Tweets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ye Lin
  • Fonction : Auteur
  • PersonId : 945290
This paper explores elegant design variations for Spirographs to display Tweets. Our method consisted in first tweaking Spirographs parameters using a drawing tool we developed specifically. We then identified particularly interesting Spirographs patterns and gave them flower names to better recall and describe them: sunflower, daisy or chrysanthemum, to name a few. We further customized those patterns, and eventually combined them with other Spirographs to construct more complex ones. As those Spirographs patterns were well suited to segment time into hours or minutes with their "petals", we investigated one particular scenario: Tweets visualization collected during CHI 2013, where each Tweet is represented as a particle that decorates the Spirographs. The resulting visualization is appealing and efficiently shows Tweets distribution over time and trends both during short and long time spans. Those early results show that Spirographs can go beyond simple artworks and can effectively bear both attractiveness and structure, which make them perfect candidate for ambient display.
rvuillemot-spirographs.pdf (2.11 Mo) Télécharger le fichier
Format : Figure, Image
hal-00856824 , version 1 (14-09-2013)
  • HAL Id : hal-00856824 , version 1
Ye Lin, Romain Vuillemot. Spirograph Designs for Ambient Display of Tweets. IEEE VIS 2013, IEEE, Oct 2013, Atlanta, GA, United States. ⟨hal-00856824⟩
387 Consultations
1436 Téléchargements
