Circuit retiming applied to decomposed software pipelining - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Parallel and Distributed Systems Année : 1998
This paper elaborates on a new view on software pipelining, called decomposed software pipelining. The approach is to decouple the problem into resource constraints and dependence constraints. Resource constraints management amounts to scheduling an acyclic graph subject to resource constraints for which an efficiency bound is known, resulting in a bound for loop scheduling. The acyclic graph is obtained by cutting some particular edges of the (cyclic) dependence graph. In this paper, we cut edges in a different way, using circuit retiming algorithms, so as to minimize both the longest dependence path in the acyclic graph, and the number of edges in the acyclic graph. With this technique, we improve the efficiency bound given for Gasperoni and Schwlegelshohn algorithm, and we reduce the constraints that remain for the acyclic problem. We believe this framework to be of interest because it brings a new insight into the software problem by establishing its deep link with the circuit retiming problem
Fichier non déposé
hal-00856850 , version 1 (02-09-2013)
Pierre-Yves Calland, Alain Darte, Yves Robert. Circuit retiming applied to decomposed software pipelining. IEEE Transactions on Parallel and Distributed Systems, 1998, 9 (1), pp.24-35. ⟨10.1109/71.655240⟩. ⟨hal-00856850⟩
49 Consultations
0 Téléchargements
