A new SSI algorithm for LPTV systems: application to a hinged-bladed helicopter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mechanical Systems and Signal Processing Année : 2014
Joseph Morlier
Many systems such as turbo-generators, wind turbines and helicopters show intrinsic time-periodic behaviors. Usually, these structures are considered to be faithfully modeled as linear time-invariant (LTI). In some cases where the rotor is anisotropic, this modeling does not hold and the equations of motion lead necessarily to a linear periodically time- varying (referred to as LPTV in the control and digital signal field or LTP in the mechanical and nonlinear dynamics world) model. Classical modal analysis methodologies based on the classical time-invariant eigenstructure (frequencies and damping ratios) of the system no more apply. This is the case in particular for subspace methods. For such time-periodic systems, the modal analysis can be described by characteristic exponents called Floquet multipliers. The aim of this paper is to suggest a new subspace-based algorithm that is able to extract these multipliers and the corresponding frequencies and damping ratios. The algorithm is then tested on a numerical model of a hinged-bladed helicopter on the ground.
Morlier_9433.pdf (370.7 Ko) Télécharger le fichier
hal-00863703 , version 1 (30-07-2018)
Ahmed Jhinaoui, Laurent Mevel, Joseph Morlier. A new SSI algorithm for LPTV systems: application to a hinged-bladed helicopter. Mechanical Systems and Signal Processing, 2014, 42 (1), pp.152--166. ⟨10.1016/j.ymssp.2013.08.006⟩. ⟨hal-00863703⟩
385 Consultations
214 Téléchargements
