Abstract : The contribution of this paper is twofold. First, a new spatial domain image registration technique with subpixel accuracy is presented. This technique is based on a double maximization of the correlation coefficient and provides a closed-form solu- tion to the subpixel translation estimation problem. Second, an efficient iterative scheme for integer registration is proposed, which reduces significantly the number of searches, as com- pared to the exhaustive search. This scheme can be used as a pre-processing step in the sub-pixel accuracy technique, lead- ing to lower computational complexity. Extensive simulation results have shown that the performance of the proposed tech- nique compares very favorably with respect to existing ones.
https://hal.inria.fr/hal-00865121 Contributor : Perception teamConnect in order to contact the contributor Submitted on : Tuesday, September 24, 2013 - 1:54:16 PM Last modification on : Saturday, February 23, 2019 - 10:53:36 PM Long-term archiving on: : Wednesday, December 25, 2013 - 4:32:01 AM
