Value at Risk with tempered multistable motions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This is an empirical work showing numerically the importance of taking into account non-stationarities in CGMY and similar models for computing VaRs. More precisely we model S&P 500 logs with a CGMY model, but where the parameters are allowed to vary. We show that C, G, M and Y in- deed display significant variations across time. Most relevant is the variation of Y , which implies that the correct modelling frame is the one of tempered multistable motions, a recently introduced class of stochastic processes. We provide experimental evidence that these variations have a notable impact on VaR estimation, and thus should be taken into account for proper risk evaluation.
Value_at_Risk_with_tempered_multistable.pdf (841.54 Ko) Télécharger le fichier
hal-00868634 , version 1 (01-10-2013)
  • HAL Id : hal-00868634 , version 1
Hicham El Mekeddem, Jacques Lévy Véhel. Value at Risk with tempered multistable motions. 30th International French Finance Association Conference, May 2013, Lyon, France. ⟨hal-00868634⟩
414 Consultations
209 Téléchargements
