Common TCP Evaluation Suite - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
This document presents an evaluation test suite for the initial assessment of proposed TCP modifications. The goal of the test suite is to allow researchers to quickly and easily evaluate their proposed TCP extensions in simulators and testbeds using a common set of well-defined, standard test cases, in order to compare and contrast proposals against standard TCP as well as other proposed modifications. This test suite is not intended to result in an exhaustive evaluation of a proposed TCP modification or new congestion control mechanism. Instead, the focus is on quickly and easily generating an initial evaluation report that allows the networking community to understand and discuss the behavioral aspects of a new proposal, in order to guide further experimentation that will be needed to fully investigate the specific aspects of a new proposal.
Fichier non déposé
hal-00868706 , version 1 (01-10-2013)
  • HAL Id : hal-00868706 , version 1
David Andrew Hayes, David Ros Sanchez, Lachlan Andrew, Sally Floyd. Common TCP Evaluation Suite. [Research Report] Dépt. Réseaux, Sécurité et Multimédia (Institut Mines-Télécom-Télécom Bretagne-UEB); Department of informatics (University of Oslo); Centre for Advanced Internet Architectures - Faculty of Informatio (Swinburne Institute of Technology); Institut de recherche en informatique et systèmes aléatoires (UMR CNRS 6074 - Université de Rennes 1 - INRIA - INSA de Rennes - ENS de Cachan - Télécom Bretagne - Université de Bretagne Sud); International Computer Science Institute - Center for Internet Research (University of California, Berkeley). 2013. ⟨hal-00868706⟩
248 Consultations
0 Téléchargements
