Imaging of the optic chiasm and retrochiasmal visual pathways - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Diagnostic and Interventional Imaging Année : 2013
The exploration of the chiasmal and retrochiasmal visual pathways is based on magnetic resonance imaging. A bitemporal hemianopsis suggests a lesion of the optic chiasm while homonymous lateral hemianopsis should lead to a search for a lesion of the retrochiasmal visual pathways. The causes of chiasmal impairment are mainly tumoral. The exploration protocol is based on MRI with T1-weighted sagittal sections, then T2- and T1-weighted coronal sections with and without injection. In case of a retrochiasmal syndrome, the MRI exploration protocol is a function of the type of occurrence of the deficiency and the context.
hal-00878500 , version 1 (30-10-2013)
Nicolas Menjot de Champfleur, S. Menjot de Champfleur, Damien Galanaud, N. Leboucq, A. Bonafé. Imaging of the optic chiasm and retrochiasmal visual pathways. Diagnostic and Interventional Imaging, 2013, 94 (10), pp.957-971. ⟨10.1016/j.diii.2013.06.012⟩. ⟨hal-00878500⟩
123 Consultations
0 Téléchargements
