Exploring beam-based shift-reduce dependency parsing with DyALog: Results from the SPMRL 2013 shared task - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The SPMRL 2013 shared task was the op- portunity to develop and test, with promising results, a simple beam-based shift-reduce de- pendency parser on top of the tabular logic programming system DYALOG. The parser was also extended to handle ambiguous word lattices, with almost no loss w.r.t. disam- biguated input, thanks to specific training, use of oracle segmentation, and large beams. We believe that this result is an interesting new one for shift-reduce parsing.
dyalogsr.pdf (136.77 Ko) Télécharger le fichier
hal-00879129 , version 1 (31-10-2013)
  • HAL Id : hal-00879129 , version 1
Éric Villemonte de La Clergerie. Exploring beam-based shift-reduce dependency parsing with DyALog: Results from the SPMRL 2013 shared task. 4th Workshop on Statistical Parsing of Morphologically Rich Languages (SPMRL'2013), Oct 2013, Seattle, United States. ⟨hal-00879129⟩
138 Consultations
228 Téléchargements
